• เว็บไซต์นี้ใช้คุกกี้ หากต้องการใช้เว็บไซต์นี้จะถือว่าคุณยอมรับการใช้คุกกี้ของเรา. เรียนรู้เพิ่ม.
[ข่าว] XenForo 1.5.13 Released
Guys
#1
Today, we are pleased to release XenForo 1.5.13. This release fixes a number of bugs and issues that were found since the previous release. As this is a maintenance release, the vast majority of the focus was an increase in stability.
Some of the changes in this release include:
  • Disable the HTML5 uploader for older versions of Android (< 5, not using Chrome) due to incompatibilities.
  • Prevent the HTML5 uploader from creating a horizontal scrollbar with very small windows.
  • Fix an issue reverting message edits if not all of the edits could be reverted in one batch.
  • Add several new indexes for performance benefits in specific cases.
  • Ensure that several additional types of content are updated correctly when merging users.
  • Capture errors parsing bounced emails and log them for future analysis.
  • Prevent recursive calls to the image proxy by short circuiting to the final image.
  • Limit the number of image proxy records removed at a time to prevent memory errors.
  • Adjust multiple external calls in templates/JS to always use HTTPS.
  • Prevent the likes received list from being completely blank in specific situations.
  • Don't display the "log in or sign up" message on threads that have been explicitly closed.
  • Fix an incorrect permission check when quoting a user that could lead to a phantom alert being created.
  • Trim smilie replacement values when saving to prevent unexpected behavior
See the Resolved Bug Reports forum for further information.
The following templates have had changes:
  • account_likes
  • addthis_ajax
  • captcha_recaptcha
  • google_analytics
  • login_two_step
  • thread_view
Where necessary, the merge system within the "Outdated Templates" page should be used to integrate these changes.
Please note that we are now formally recommending that you upgrade to PHP 5.4 or newer. XenForo 2.0 is requires PHP 5.4 or newer. If you are running PHP 5.3 or 5.2, you will receive a warning when installing or upgrading XenForo.
All customers with active licenses may now download the new version from the customer area.
Download XenForo 1.5.13
From the Licensed Customer Area
More Stable
This release follows our principle that third-point (x.x.X) releases should always be more stable than the preceding version, so for the most part you will not find new features in this release. Major new features will be reserved for second point versions (x.X.x).
Installation and Upgrade Instructions
Full details for how to install and upgrade XenForo can be found in the XenForo Manual.
